Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-02-2003, 08:52 AM
Parasite Parasite is offline
Garage is empty, add now
Parasite is starting off with a positive reputation.
how much oil???
Hello,
I just got my first flat head truck. It is a 1936 pick up with a flat head V8. I went to do a oil change on it and was a little shocked when it read full on the dip stick after just 2 1/2 quarts. Could this be right? oil pan looks like it should hold much more than that. Also it dose not have a oil filter. Any help would be great.
Thanks,
Parasite
  #2 (permalink)
Old 07-02-2003, 10:00 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
how much oil???
It should hold 5 quarts. Often dipsticks were replaced with one from a different application (I know of at least 3 or 4 different boss style/locations for the 3 V8 series and Ford/Merc variations) and the dipsticks are different lengths. You might look at your dipstick and see if a previos owner might have filed or scribed a new line on the dipstick where 5 qts would be.
Not having a filter isn't necessarily a problem with these limited filtration flatheads - just make sure to change your oil frequently - say every 500 miles.
If you want a filter - the canisters show up frequently on ebay. You'll need the steel lines and be sure to include a restrictor to keep your oil pressure up. Filter element is available at any decent parts place.
Tags
53, capacity, flat, flathead, ford, head, oil, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
