No start with key
No start with key
I have an intermittent problem with my 2000 Ex V10 with factory remote start. Sometimes when I put the key in to start the truck, I get nothing. I believe the theft light flashes but I am not entirely sure. Sometimes after a few tries with turning the key it will start. If I hit the button for the factory remote start it always starts, so I have never gotten stuck anywhere.
This issue could happen 2 or 3 times in a row and then not happen again for days or weeks. It's been going on for a couple of years now.
Any ideas what to look at. There is no telling when it will happen again though.
Thanks.
BTW, I have stomped the brake pedal and I have moved the gear shift when it happens and sometimes on retry it starts and sometimes it does not. When I just keep trying the key sometimes it eventually starts too, so I do not think it is the safety in the brake pedal or in the shifter, but I could be wrong.
Thanks.
As for your problem, have you tried setting aside the key you always use and use your spare exclusively to eliminate the possibility that it's your key that's the problem?
Stewart
Not sure your 2000 has pats? a lot of times the remote starters need a key up under the dash so the pats detects the key and allows it to start. Perhaps that key is a duplicate of one vs a third seperately programmed and gets the security module to think you are stealing it.
edit: if there is a key under the dash, it only has to be the plastic head, not the metal "key" part, it's a security risk too. Anybody could steal your ex, if they jimmy the ignition switch, since you have a "pats" key under there..
Sent from my Sprint PC36100 using IB AutoGroup
on
It's not a factory option but like Stewart said, the dealer could have put the remote in which is probably the problem. Since they have the PATS system it complicates the remote installation which is one reason I didn't put one in mine. You can take the tiny emitter out of the key head and tape it inside near the key switch (there is an antennae that surrounds it) and then you could use any key to start it but I doubt if that would cure your problem. You could also have a clone made from your original but that might not cure it either. I think it would have been fine if a remote was never installed in it.
Since you don't touch the brake or the shift lever I don't see them affecting it. The theft light will give you a clue so pay attention to that, it is part of the PATS system. It should go out 2+- seconds after you turn the key.
Thanks.
I have a remote start on my '01 Excursion and it has a passive and active arming system. Sometimes if have a door open and I'm vacumming the interior, it will passively arm and not make a sound. I could have the key turned back and the radio on, but not a sound. (doesn't matter if I have the key turned to the first position either).
When I'm ready to start the truck and leave, all I have to do is press the unlock button on the remote and the truck will start.
I will say it scared the crap out of me when they first installed the alarm though, lol!
on
I am assuming you have 2 factory keys that look the same? If one is not working as well as the other you can make a third key pretty easily so you will at least have 2 good working keys, but I'm not saying the keys are the problem
HwyXingFrog
2004 - 2008 F150
07-23-2012 11:35 PM
spencer788
04-03-2011 08:52 PM
