05 Escape oil leak fix or not?
Old 03-10-2014, 07:56 AM
gerry2222's Avatar
gerry2222
gerry2222 is offline
Just joined.
Have quick question on my 05 Escape 3.0L. Very small leak bottom of timing chain cover. Cleaned, drove 600 miles, oil level fine.
Am I OK with just checking it. Thanks
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
Old 03-17-2014, 11:59 PM
ajwgator's Avatar
ajwgator
ajwgator is offline
I would just keep an eye on it a bit longer, say a couple of oil change cycles and see if its really that bad. If could have been spilled from an oil change some time in the past. JMO
Old 05-19-2014, 08:43 PM
PettitWC's Avatar
PettitWC
PettitWC is offline
Ditto!
I think I have the same issue on mine, but I need to work myself up want to go back in for some more. I just did the oil pan gasket and it'll need a valve cover gasket soon too, but the front crankshaft seal and timing cover gaskets are high on the list.
bass-n-fire
1997 - 2003 F150
03-24-2017 11:50 PM
lwb06
09-22-2004 09:46 PM
shel 67
Aerostar
05-15-2004 12:40 PM
tim_1911
04-02-2002 12:47 PM
sws
1997-2006 Expedition & Navigator
02-06-2002 08:29 PM
Quick Reply: 05 Escape oil leak fix or not?
