2001 F250 V10 Supercab loose door prob
Hello, New to the forum. I have an issue with a loose door. The hinges and latches are tight. The plate that is inside the rear door has a little give that results in the doors lining up about 1/4" offset between the front and rear doors. There doesn't appear to be any bolts from the exterior to adjust. Is there an inner adjustment? The latch is attached to a plate that sits inside the rear door about midway from top to bottom. It sits in an opening about 2 to 2.5 inches in diameter. I can tug on the latch and get a small amount of movement from the plate. It is more pronounced in the drivers side. I get a small amount from the passanger side as well.
Hi stewl, and welcome to the site.
That's a good question to ask in the Super Duty forum. Post up a thread and I'm sure you'll get all the help you're looking for. To find the forum, just click this link: Super Duty & Heavy Duty - Ford Truck Enthusiasts Forums
Good luck!
Good luck!
z 97ford1
10-23-2005 07:55 PM
