Rubbing down pipe, body lift?
Should I do a small body lift to fix my rubbing down pipe? It is driving me crazy hearing that thing hitting the firewall. I have tried to adjust the turbo so it wont rub but it is so tight the best that I got was about 1/32" off of the firewall and it rubs on the firewall sometimes when I'm driving. I only want to clear that pipe not do a crazy tall body lift maybe 1-1.5 inches. My body mount bushings are totally rotten and squished. Any thoughts or suggestions?
Received 3,108 Likes
on
Make some cuts in the floor pan seam then use a long piece of pipe as a pry bar to push the firewall in. Lifting the body won't necessarily make more firewall clearance, in fact most body lift kits specify "not for diesel" because of clearance issues between the cylinder head and floor pan seam.
bigcountry62
04-22-2013 12:29 PM
