Coolant flush with faulty EGR cooler?
I believe I have a busted EGR cooler, and am preparing to replace it along with the oil cooler, etc. I want to perform a cooling system flush with Restore before I tear into it, but I get the feeling that would be a bad thing to do with a leaking EGR cooler.
What are the risks of running my 6.0L with a bad EGR cooler?
That's the common remedy. The bottom end is pretty stout on a 6.0. I've hydrolocked mine a couple of times changing injectors and never bent a rod. It did bend one running some stupid high RPM's one day, but I wasn't driving. It ran for 3 more weeks before I tore it down.
Thanks for the feedback!
Two things about that approach:
1) I'm replacing the EGR cooler rather than doing a delete.
2) I don't want to tear it down twice
Though, you do make a good point that I'll have to consider.
Alright - so..
- tear it down, replace the EGR cooler
- put it all back together
- flush the coolant system
- tear it all apart again and replace the oil cooler.
Can I reuse the old EGR cooler gaskets for the flush, then replace them with new when I put it back together the final time? Are EGR gaskets reusable? What about intake gaskets?
Alright - so..
