Door lock cylinder; what's the secret to removing
Last weekend when the weather was warm I tore into the passenger side door on old Stanley to re-attach the inside door handle to the linkage. I wanted to remove everything in the door to inspect, grease, reassemble, and prepare for installation of the new door glass and rubber. I was only partially successful. I was unable to remove the door latch because the flat key from the door lock cylinder runs through it, and I wasn't having any success at turning the "screw" for the cylinder that's behind the door weatherstrip. The manual refers to it as a "screw" but it looks more like a rounded-out allen screw to me. I found nothing that will fit it. I have attached a picture. Anybody know what makes this thing move?
I had the exact same problem Friday! Thought about drilling it out, but before that thought about easy outs. Then on a whim, I took a small Craftsman Phillips screw driver and pushed against the screw while turning it. To my surprise, it backed out without a problem. It's a fine thread screw. I'm hoping to find a headed screw, same thread and length from Fastenal. Good luck.
The Bristol fastener was new for me, too. Good info.
If you can get the set screw out, you shouldn't need to put back a headed screw. The set screw will work fine. Make sure your threads are clean and put the set screw back with some anti-seize. As tight as the area is under the rubber, the head will get in the way.
out of curiousity, if you have no intention of saving the lock cylinder, is there an easier way to accomplish this if it is stuck (i.e. can you just drill it out)?
Reason I ask is I am about to tackle this and my lock cylinder has already been butchered by some back woods lock smith with a drill bit.
