2005 E-250 transmission Which one????
2005 E-250 4.6 with trans code A
So I have a 4R75E ID 5C2P-CA
Can i use the 4R75E out of the 5.4 motor van??
4R75E ID 5C2P-DA
4R75E ID 5C2P-EA
Can these be interchanged ?
since they are All 4R75E with they work???
I want to get a used one from a junkyard but dont know if they will work
4R75E ID 5C2P-DA
4R75E ID 5C2P-EA
My research showed same internal wiring and electronics . 4r75E are the same animal . Put one in and call n worked great. There r a couple of variations but if it bolts up and has same sensors I figured I was ok. Well 4000 miles now still working great. Best part 400.00 at local yard !!!!!! Thanks FTE
Fomoko1
39
05-06-2007 12:54 AM
