1600cc rough idle when warmed up
Old 06-26-2003, 06:29 AM
Trackhead's Avatar
Trackhead
Trackhead is offline
Not sure where to post this...Anyway, my snowcat has an old 1972 Ford 98 CID/1.6Liter/four cylinder industrial engine (Pinto basically). Starts great, runs great until warm. Then has a very rough idle to the point of near stalling. Once the RPM's are a bit higher it runs fine with good power, etc. Vacuum leak? Any tips? Thanks in advance.
Old 06-27-2003, 08:00 PM
canzus's Avatar
canzus
canzus is offline
It's not a Pinto, it's a Kent, and it may have
carb troubles, idle circuit may be kinda lean too
little fuel, check the idle mixture screw is about
2 or so turns out from gently all the way in when
hot.
Old 07-06-2003, 05:10 AM
shotgun's Avatar
shotgun
shotgun is offline
Probable a gummed up idle circuit.
WhiteBeast-05-powers
11-09-2013 12:47 PM
dwood3311
11-18-2011 10:36 AM
magneto259
1983 - 2012 Ranger & B-Series
11-20-2009 04:44 AM
bassin88
1999 to 2016 Super Duty
10-11-2009 07:50 AM
F-150kekec
Modular V8 (4.6L, 5.4L)
09-25-2004 12:34 PM
Quick Reply: 1600cc rough idle when warmed up
