Well after trolling this website for the longest and looking through various parts sites and schematics I can't figure out what this leak is coming from on my C6 Transmission
Sorry, for clarification what connection is this? It seems that it has been tightend down too tightly as the plastic is worn and deteriorated and has been a problem for a while. When in doubt top her off was the previous owners motto.
A speedo cable is the only thing I can think of that would be that far back in the transmission. It's almost like it's hooked up to the governor though.
There is a huge amount of air rushing through there because of the huge opening in the grill area, so look forward for the leak. Follow the wet. I suspect your leak is at the front seal of the tranny and the wind is pushing it to the rear. Speedo connectors usually are not big leakers.
jowilker is right. You could also start by cleaning it and then take a drive. Then re-inspect for the leaky culprit. In the pic it looks like most if not all of the tranny is fluid soaked.
If you look closely at the floor board in second pic (top left)you can see it has spun off the universal covering area with tar looking gunk. Mine did that when it was leaking from rear seal. Obviously, there is another leak and I would lay money on front seal or where cooling line connect.
I'm thinkin' it's leaking from multiple sites. Like there is too much fluid in it. Maybe it's got the wrong dipstick in it so what looks like "full" is actually too much. What is the engineering number off your dipstick? I'll cross it over and see if it is correct.
