I have a 2002 Ford F2 50 that has a diesel leak on the back of the engine. I've already replaced the drain valve that was leaking. Then I noticed that the front of the engine was dry now but the back of the engine still has some pooling With a very small drip off the back of the engine between the transmission housing and engine. Not as bad as it was of course But still a small drip. Any ideas where this may be coming from? And how to fix it?
Check the metal fuel line coming off the back of the passenger side head.there is a bracket that has a habit of rubbing the line through.look on side of valve cover you will see the bracket with the line running through it
