Number Dummy, can you look up fastners NOS?
Looking to find a source for the two caged nuts that clip into the top of the bottom rail of the radiator core support just on either side of centerline. Truck is a 1966 F100 2WD. From the 64-72 master parts catalog: the item is listed as 359218-S (MM-210) and depicted in the chassis Parts Group, illustration Section 82, page 2 - Radiator grille and related parts.
Thanks
Thanks
Does this work?
359218S2 | RearCounter.com | 35 found at 2 sellers
Those are for the bottom of the hood latch supports and the grille.
I did not realize the bolt/nut/hardware numbers work on rear counter !!! Nothing like learning something new that will make your truck reconstruction so much easier. We have two 66s and they are missing on both. In both cases the support was drilled through and long bolts were used with nuts on the bottom, however that tends to deform the lower support rail. I will give DC a call tomorrow.
Truck is a 1966 F100 2WD. From the 64-72 master parts catalog: the item is listed as 359218S and depicted in the chassis Parts Group, illustration Section 82, page 2 - Radiator grille and related parts.
If you had typed it like this into PartsVoice.com .. you would not have received any results.
rearcounter.com is more forgiving as TA455HO discovered. When typed as 359218S, the 2 suffix appears.
Parts catalog illustrations may not show the complete Standard (aka hardware) part number. The text section is necessary to verify.
The number is parentheses is meaningless, as it's the FoMoCo dealer bin location.
359218S2 =
GREEN SALES CO. in Cincinnati OH has 16 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 19 = 800-476-9653.
unibody62
09-18-2017 05:46 PM
tvliftcabinet
05-16-2017 01:10 PM
thatone
08-02-2012 10:28 AM
PA74F250
09-13-2010 12:01 PM
fastmover
03-20-2008 11:54 PM
