2003 Excursion Limited Sputtering and Stalling
Old 02-18-2014, 06:00 PM
nstubbert's Avatar
nstubbert
nstubbert is offline
Ok, my 2003 Ex Limited with 109,000 started doing the same thing today that it has done many times before. It started shuttering and then stalled. It comes out of nowhere and then the overdrive light flashes at the same time. I have had the coil packs replaced in the past, but not all of them at once. I also had the torque converter replaced last year as well. I am pretty sure that it's more coil packs that need to be replaced again. I'm sick and tired of replacing coil packs on this truck, it seems like they go bad very quickly. It's so bad I'm thinking about getting rid of this truck and getting something different. Any suggestions on what you think might be the problem and how to prevent this in the future? Thanks
Old 02-18-2014, 06:30 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
If the OD light is flashing, you have transmission codes you should get read. Sounds like a tranny issue.
Old 02-18-2014, 06:33 PM
EXv10's Avatar
EXv10
EXv10 is offline
Sounds more like boots and water in the holes.
Old 02-18-2014, 06:55 PM
nstubbert's Avatar
nstubbert
That's what I'm thinking too. It happened earlier this winter when we got a lot of rain....it would shutter and stall and the engine light came on along with the flashing OD light. When I took it to the garage it was running fine and they got a code but it was just a misfire code. They charged me a half hour in labor and sent me out the door. That was about a month ago and it's been running fine until today. Occasionally it will stutter a little bit going up a hill of if I'm towing something but nothing too bad. What should I do?
Old 02-18-2014, 10:12 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
I'm not saying you don't have a bad coil or coil boot too, but a bad coil will not cause a transmission code, which is what causes the OD light to flash.
Stewart
Old 02-19-2014, 06:35 AM
nstubbert's Avatar
nstubbert
Stewart
The last time this happened (about a month ago) it did the same exact thing...it was shuttering, stalling and the OD light was flashing. I brought it into the shop and the only code they got was a misfire code....I put some dry gas in before I dropped it off at the shop. I don't know if that fixed it or not, but I had no problems until yesterday and now the same thing....shuttering, stalling and OD light flashing...it doesn't make sense to me at all.
Old 02-19-2014, 09:30 AM
EXv10's Avatar
EXv10
EXv10 is offline
Do my water leak and boot fix after you check the boots.
https://www.ford-trucks.com/forums/1...l#post12209418
This was my first how to so it wasn't step by step.
Old 02-19-2014, 12:30 PM
Stewart_H's Avatar
Stewart_H
Me either.
A misfire should cause your check engine light (SES light, MIL, etc) to activate. The OD flashing is the transmission SES light, so-to-speak.
Like you indicated, confusing.
Stewart
Old 02-19-2014, 01:20 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
Me either.
Stewart
This ^
Your O/D light will not flash due to an engine misfire. It flashes solely to signify a transmission issue.
We're not suggesting you don't have a misfire. Just that you also have something going on in the trans.
Old 02-19-2014, 02:12 PM
EXv10's Avatar
EXv10
EXv10 is offline
Originally Posted by duck fan
This ^
That's what I was thinking. Why would the dedicated blinker blink for something else?
Old 02-19-2014, 06:06 PM
nstubbert's Avatar
nstubbert
Ok guys, how about this? I drove my Ex today and no problems whatsoever. I took it to my mechanic and he hooked it up to the diagnostic and the only code that came up was for a speed sensor. He said that the speed sensor shouldn't be causing the problems that I am having.....any thoughts???
Old 02-19-2014, 08:52 PM
EXv10's Avatar
EXv10
EXv10 is offline
Yea, check your boots and fix your leak before proceeding.
Old 02-20-2014, 06:29 AM
nstubbert's Avatar
nstubbert
Can you be more specific on how to build the "bridge?" I'm not really sure what you mean by that, and what should I use to seal it up?
Old 02-20-2014, 09:51 AM
EXv10's Avatar
EXv10
EXv10 is offline
You will see where the 2 plastic pieces come together after you take the long soft rubber piece off. They leave a gap between them about 1/4" +- so just glue something across that gap (plastic, metal, anything), now use any sealer you have laying around on it. (I used some tub sealer in a tube). The water goes UNDER the long rubber piece.
Old 02-20-2014, 10:54 AM
nstubbert's Avatar
nstubbert
Thanks, I will give it a try
Quick Reply: 2003 Excursion Limited Sputtering and Stalling
