Super Cab Pop-Out Windows
I understand that the locking part is the same from the Pintos and Bobcats. If you can get someone here to give you a part number, you could probably find them NOS, or in the junk yard.
I know LMC has the windows and the plastic hinges. I know I have to order the plastic inserts my self for my supercab wing windows. If you want used whole windows,they are on ebay time to time. I,myself, am wondering if there is a plastic cover that goes on the outside of the handle. Looks like there is a recessed place for a snap in cover to go. Any trucks that I have seen have no cover on them??
Do you mean hard as in hard to latch?
If so, often the window seal gets super stiff when it's old. One solution may be to replace the window seal and they might not be so hard to close.
The roll pins that go to the metal/chrome arm do tend to rust or get stiff. They can be pressed out and replaces with a cap head screw and cap nut. This may fix any stiffness in movement for the hinge. It also supplies some holding pressure that the roll pin cannot supply.
1974/79 Super Cab 'Pop-Out' Quarter Windows
If y'all need any of these parts, quote the part number(s). I'll see if anyone has any NOS / See 2nd parts catalog pic.
D4TZ-10302A02-A .. Quarter Window Latch Retainer / Right/Left same / Obsolete
1974/79 Super Cab.
D4TZ-10302A06-A .. Quarter Window Latch Retainer Spacer / Right/Left same / Obsolete
1974/79 Super Cab.
D2FZ-7330212-A .. Window Handle Retainer / Right/Left same / Obsolete
1974/79 Super Cab / 1972/80 Pinto/Bobcat Station Wagon / 1974/78 Mustang II Fastback.
D2FZ-73302A12-A .. Quarter Window Hinge Retainer / Right/Left same / Obsolete
1974 Super Cab / 1972 Pinto/Bobcat Station Wagon.
D5FZ-73302A12-A .. Quarter Window Hinge Retainer / Right/Left same / Obsolete
1975/79 Super Cab / 1973/80 Pinto/Bobcat Station Wagon.
D4TZ-10303A24-A .. Quarter Window Latch-Right / Obsolete
1974/79 Super Cab.
D4TZ-10303A24-B .. Quarter Window Latch-Left / Obsolete
1974/79 Super Cab.
DODZ-6230330-A .. Quarter Window Latch Roll Pin-3/4" long / Right/Left same / Obsolete
DODZ-6230330-B .. Quarter Window Latch Roll Pin-1/2" long / Right/Left same / Obsolete
1974/79 Super Cab / 1970/77 Maverick/Comet / 1971/80 Pinto/Bobcat except Station Wagon / 1974/78 Mustang II Fastback.
Lower pic:
1974/79 Super Cab.
1974/79 Super Cab.
1974/79 Super Cab.
1974/79 Super Cab.
Lower pic:
NOS Part LTD has them all! Thanks a million for the diagram.
www.nospartsltd.com NOS Parts Ltd is an independent parts warehouse that specializes in providing Obsolete New Old Stock Ford parts for Ford and Lincoln - Mercury cars and trucks.
79 supercab pop out rear windows
Does anyone have any of the latches, with or without the window laying around they would be willing to sell? Cannot find them anywhere. I am located in Maryland and the junkyards do not seem to having any old dentsides. Or has anyone retrofitted the 70's supercabs with any newer window latches that worked? Thanks in advance.
Casey
Casey
