Master cylinder location
Hey guys, got a couple of questions. I've gotten far enough along into my build to start on systems. This truck is pretty unusual - short bed '57 on S10 frame with sbc power. (The original frame was long gone). Will a power brake booster clear a v-8 in the stock location? Or do they usually have to be moved? I won't have the engine for a while. Also any recommendations for cab corners?
I'm running an automatic so the clutch master cylinder won't be a problem. This truck was my old hot rod from the '70s. I was running a big block Pontiac in it then and in the process of rebuilding it (from what parts I had left) I noticed the master cylinder had been relocated to the clutch side. I don't remember why this was done, or whether the previous owner had done it before I got the truck!
I know some of the guys here install big blocks in there trucks so I just wanted to know if there is usually interference with the engine. Otherwise I'll just take some measurements and mock the thing up in the stock location. I really want to get the brake lines finished up without having to wait to install the motor.
stagecall
04-24-2016 09:53 PM
chetspencer
31
10-12-2012 07:31 AM
svooom
06-09-2004 07:46 AM
GreatNorthWoods
09-22-2002 10:41 PM
johns54
06-22-2002 09:28 PM
