Headers or not
Headers or not
I have a 1978 supercab 4x4 f-250 truck with the 400 v-8 stock engine. What are your opinions out there about headers vs. stock manifold exhaust system -(which is what mine is.) I have a stock 2 bb. carb on it. If headers,is a 4 bbl. better? Painted or ceramic coated headers? Shorty or full length system? Ease of installment on this particular truck? My stock manifolds have been loosened so bolt breakage during removal shouldn't be a problem. Thanks,Randy
If you ever intend on swapping a 4bbl onto it go with headers so it can breathe. Unless you have some serious performance parts just stick with painted and I went with the long tube but that was just a preference thing for me. Also being that it is 4wd try to find the kind that go outside frame rails, you will thank me for that tip ha ha
FWIW, here is what I am going to install on my 79 F350 4x4 SC with the 400. Going with the MSD Ignition 8350 - MSD Pro-Billet Ready-To-Run Distributors, MSD Ignition 8200 - MSD Blaster 2 Ignition Coils, MSD Ignition 6425 - MSD Digital 6AL Ignition Controllers. Below are the carb & headers. This will be a much needed upgrade over the current stock setup.
http://www.summitracing.com/parts/bi...rd/model/f-350
http://www.summitracing.com/parts/edl-1406/overview/
You are half way there.....IMO frame exit (outside the frame exit) are the easiest and cheapest to finish the rest of the exhaust sys. You can even you do it yourself...
Painted $ are cheaper that ceramic $$$. Ceramic might be a back order if you use L&L?
Headers now, then alum intake and 4 bbl ASAP, then one thing after another. Straight up timing set....
Get the thick Jeffs Bronco Graveyard header gaskets and the locking Nord-Loc lock washers (Fastenall) along with some quality grade 8 hardware.
And put some anti-seize on the bolts.
Rich, I'm not sure L & L offers the headers for 78/79 400 engines? I know my son put a set on his 429 (1977 hiboy-fender exits) but I didn't think they were available for the 400 engines...might be wrong...?
