Truck sputtering/bogging under load, I am stumped
Hi everyone, this is going to be a long post so please bear with me.
I have a 93 F150 XLT 5.0L/E4OD 2wd.
I recently swapped the exhaust manifolds for BBK Shorty headers, removed/cleaned the upper air intake, rebuilt all the injectors, new cap, rotor, spark plug wires and replaced some of the old vacuum lines with new ones.
When I first got the truck back together it was running horribly and had a terrible exhaust leak. Turns out the EGR tube to the intake manifold had a crack in it so I fixed that and hoped for the best. The exhaust leak is gone but the truck doesn't want to run right when I am driving it.
It starts and idles fine but as soon as it is in gear and I start moving it bucks/sputters/bogs really bad almost as if I am down a cylinder. Prior to my "upgrades" the truck was running fine other than the exhaust gasket on the one side being blown.
When I was taking it apart there was a ground strap from the passenger side firewall to the passengers side of the engine block. I broke this strap when I was removing it and haven't replaced it yet, could this be causing my issues?
If I messed up one of the fuel injector o-rings during re-assembly would it cause a vacuum or fuel leak? There is NO raw fuel smell with the truck running and everything appears dry.
I have double checked my spark plug wire routing and it is correct so crossfire isn't the problem.
I am at my wits end and the wife isn't too pleased with the amount of time I have spent working on the truck this weekend, so any help/suggestions you guys can provide will be a HUGE help.
Thanks,
Grant
Thanks,
Grant
I'd advise doing a smoke test for vacuum leaks first. Then we can proceed from there.
ok so last night I unhooked the battery to clear any codes that may have been stored and re-connected the ground strap. The strap originally connected to one of the exhaust manifold bolts but it wouldn't reach so I attached it to the side of the upper intake manifold, will this work as a ground point?
I drove the truck to work today and it is running really bad, I am going to see if I can get it scanned for codes and go from there. I will let you guys know what codes are found.
de_madness
18
03-20-2019 12:38 PM
jcsloan2000
1997 - 2003 F150
05-04-2014 12:01 PM
