Stumped! p0301 p0306 p0171 p0174 - Ford Truck Enthusiasts Forums
Old 01-13-2018, 06:03 PM
bren_tx bren_tx is offline
bren_tx is starting off with a positive reputation.
I was pulling a trailer the other day and noticed the truck began running rough and now is hardly driveable. Engine has a hard miss both cold and hot. If I reset the codes, the p0301 comes back very quick and the other codes will eventually come back after driving. I have dual exhaust and I can hear the bank 1 is much more rough than 2.
So, I've changed all of the plugs, except for #4, may do that one today. I've changed 3 coils on 1, 5, 6. I've taken most of the fuel injectors off and cleaned them using carb cleaner and a 9v battery, so I know they're all working. Tested fuel pressure...its low but within spec at 31psi. New fuel filter.
I'm going to changed the #4 plug and coil today, but I have a feeling that it won't solve my problem. I'm totally stumped. I didn't have any lean codes until this happened. Could it be the maf?
99 f250 5.4
Old 01-14-2018, 07:51 AM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is offline
enriched&beyound is gaining momentum as a positive member of FTE.
Did you check the PCV elbow on the passenger side way back on the firewall. This goes to the rear of the intake manifold. Best to check all the vacuum lines. The p0171 and p0174 indicate a vacuum leak, which can create misfire condition. OR....you may have a intake leak, depending on how yours is equipt, either crack in a plastic intake manifold or gasket failure with either the plastic or alum intakes.
What you have done so far is good, but probably would good to change all the spark plugs and reseal the boots with dielectric grease
Old 01-14-2018, 03:28 PM
I will check for leaks in the intake. Its just crazy to me that the engine went immediately from great to poor, instead of a gradual decline. Its obvious that something mechanically failed.
Ive been thinking about how #6 fires opposite of #1 (so when #1 is TDC on the exhaust stroke) and what this could mean.
I havent noticed any coolant leaking but have come across many articles about intake leaks when I googled the codes.
p0401,p0171,p0316,p0301,p0303, pending p1507 and pending p0308 CoolitKen 1968-2013 Full Size Vans 11 08-10-2017 07:53 AM
Fuel pump, cats, or both? 6.8 V10 FTreeFidd 1999 to 2016 Super Duty 5 07-10-2017 01:11 AM
Misfire and generally running like crap BrentD22 1997 - 2003 F150 4 01-27-2017 01:07 AM
2006 F-150 5.4 P0053 Stevenmed 2004 - 2008 F150 4 03-11-2016 11:28 AM
Help! P0301, P0302, and P0171 codes. Alanpeder Modular V8 (4.6L, 5.4L) 1 02-20-2016 12:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
