Is this a normal start?
I can't hear any audio but even at -5*F my truck does not blow black smoke like that. And in warm weather no smoke at all. To me it's not normal how does it run? Is it down on power at all. Oooo just got audio going No NOT normal at all should be nice and smooth running esp. At 50*F. We have had our first up to freezing point in three weeks here been sub zero and well below freezing for weeks and even not plugged in my truck doesn't cold start like that. Do you have any way to read engine data? To check Ficm voltages and such. One I the more experienced guys will hopefully chime I. But you need to be able to read vitals to narrow down what's Happening.
Once it warms up, it runs perfectly. I don't think it's missing power, it can pull our Airstream over mountains at 70 mph without struggling. I bought the truck used about 2.5 years ago, so I don't know what they were like when they were new.
I took this video of our 6.0L F-250 starting this morning. Temperature was about 50 degrees F, but it was down around freezing overnight. The block heater was not plugged in.
Is this normal?
2006 F-250 cold start - YouTube
Thanks.
Is this normal?
Thanks.
thats not normal being that warm. sounds like mine did when the ficm was on its way out. it blew the black smoke and everything exactly like yours. id get it checked out if i were you. mine left me at my buddies farm. once i got it running i had to run 80mph down main roads to keep it running. pulled in the driveway and she shut down. after it went to the shop my mechanic found out that the internals were fried on the ficm not all the way but to the point that the injectors were firing whenever they damn well pleased with no governing of fuel going into the cylinders. so on top of having a horrible miss she was loading up as well. just my 2 cents. hopefully you get it figured out and it aint something bigger
I've never noticed the black smoke before. I don't know if that's because it wasn't there, or if I just never noticed it.
I run whatever oil the manual recommends for towing year round (15W-40 IIRC) because the amount of miles I drive when I'm not towing in the winter is small enough that I still put the heavier oil in.
Are these problems related to the coolant blowing out the recovery cap under load? Or am I in for yet more cash?
I have an OBD-II reader for my old iPhone, but I know at least it doesn't read the EOT for some reason...it just doesn't appear on the list of variables.
The "rolling" sound is getting worse - it sounds like a cylinder or two isn't firing. About a year ago, a Ford dealer said it's normal and I should use the block heater when it's below freezing (which can't be right - this is Washington, DC, where the lows are usually no worse than 15 F). I will say that today's start was an excellent one to record - it's not usually quite as bad as it was in the video - I thought it was going to stall, which isn't a feeling I usually have. No CEL. 112,000 miles. I've never noticed the black smoke before. I don't know if that's because it wasn't there, or if I just never noticed it. I run whatever oil the manual recommends for towing year round (15W-40 IIRC) because the amount of miles I drive when I'm not towing in the winter is small enough that I still put the heavier oil in. Are these problems aren't related to the coolant blowing out the recovery cap under load? Or am I in for yet more cash? I have an OBD-II reader for my old iPhone, but I know at least it doesn't read the EOT for some reason...it just doesn't appear on the list of variables.
My manual says the truck should start to -10*F without being plugged in. It recommends at least three hours of the block heater in conditions colder than that.
I'm about 10 seconds from going on a rant about my newfound hatred of this truck. You've all heard it a million times I'm sure. This is the first diesel I've ever purchased, and it's the last.
