Need help with REAR end selection!!!!
Here is what I am running. I am installing a 302/340 horse crate motor running a C4 transmission that I already have. I was wanting to install a Ford 8.8 out of an explorer with the disc breaks and locker. So my question remains is what size gears would I need to have in the rear end to be the best. I was thinking of 373 locker. Any suggestions. Thanks for all the knowledge.
Mitchell
Mitchell
what size tires. I have 235-75R15 that are about 29" dia., a 2.91 rear and 4 speed AT. At 70 mph the engine is turning 2360 rpm in 3rd, 1652 in 4th. A little low but probably ok with a torquey engine and not pulling a load. A 3.73 rear would be running 3026 in 3rd and 2118 in 4th. A 3.50 about halfway between these 2. I might pull my camper trailer with mine so I might go looking for 3.50 - 3.73 gears some day.
26.7 in diameter tires with 3.73 rear and C4 tranny you'll be turning 3287 rpm at 70 mph. Seems a bit high. I've read that the Explorers also had 3.27 and 3.55 trac-loc rears but seems the 3.73 is most common. Your's will be pretty quick off the line with a 3.73 and those wide meats out back. Good luck with your build.
Received 4,197 Likes
on
I was considering an explorer 8.8 in mine. My local wrecking yard had about 20 explorers. The majority of them were 3.55 drum rear ends. All the others were 3.73 with either drum or disc. The tag will show 3L73 if it is traction lock and just 373 if its open. My personal preference with a C4 would be the 3.55. That engine has more than enough torque to handle a more highway friendly gear. Of course I'm not a C4 fan really....I like the AOD.
Alright guys without me starting a new thread seeing if yall might have any advice. With the new 8.8 rear end I am planning on installing 20x10 in the rear and 18x8 in the front. Do I Have to install widened rear fenders or do you think I would be able to retain stock rear fenders. These are smooth steel wheels.
Thanks
Thanks
on
Well got my 8.8 rear end. Stripped it down, replaced rotors, pads, bearings, and flushed and refilled oil. Painted it black and painted diff cover the color truck will be. I know I have to cut old perches off but just couldn't stop. Good to see it looking nice though.
[IMG]<a href="http://s1371.photobucket.com/user/mitchellbwhite/media/Ole%20Bessie/IMG_7050_zps40b2ae04.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag288/mitchellbwhite/Ole%20Bessie/IMG_7050_zps40b2ae04.jpg" border="0" alt=" photo IMG_7050_zps40b2ae04.jpg"/></a>[/IMG]
[IMG]<a href="http://s1371.photobucket.com/user/mitchellbwhite/media/Ole%20Bessie/IMG_7051_zpsc1510941.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag288/mitchellbwhite/Ole%20Bessie/IMG_7051_zpsc1510941.jpg" border="0" alt=" photo IMG_7051_zpsc1510941.jpg"/></a>[/IMG]
[IMG]<a href="http://s1371.photobucket.com/user/mitchellbwhite/media/Ole%20Bessie/IMG_7052_zps98b5a139.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag288/mitchellbwhite/Ole%20Bessie/IMG_7052_zps98b5a139.jpg" border="0" alt=" photo IMG_7052_zps98b5a139.jpg"/></a>[/IMG]
Thanks
Thanks
I think 10 " will be to wide if the truck is lowered. I have 17X8 with 235/55-17 tires and have about 1/2 " clearance on each side of the tire. (bedside & fender side)
Glaser67
11-02-2016 07:11 PM
jonathan.e.green
17
09-11-2015 12:18 PM
fyrrmann
10-26-2004 06:02 PM
Opiewan
09-29-2003 08:20 PM
