questions about hard/cold starts
So on a normal day here in the new york winter the temp is about 10-30 degrees and if i dont have my truck plugged in at night it will take anywhere from 15-30 min before i finally get the truck to start and there is white smoke and the smell of unburnt fuel from the exhaust. when i do get the truck to start my nieghborhood is nothing but a big white cloud and smells of unburt diesel and i know this is bad but sometimes i have to give it half throttle and even then that doesnt work..... i let the glow plugs cycle two times; i have the led upgrade and i wait for it to go out.... sometimes if i let it crank for 20-30 sec and then cycle the glow plugs again she will fire up after about 15 sec of cranking. i am familiar with diesel and i think that my truck cranks longer than normal to start compared to most of the other trucks i hear, they crank like 5 sec and mine will crank 15-20 sec and fire. i am leaning towards possible injector o-rings. i dont have any scan devices to monitor everything and i am hoping that it isnt a hpop or lpop, i just dont have the funding for those at the moment. i am thinking that it could also be a poss ipr not to sure. any type of suggestions are welcome.
I think you should back up a little bit. This sounds like a classic non-functioning glow plug system. Likely due to a failing GPR, or glow plug relay. You can test it by following the instructions here:
https://sites.google.com/site/woodnt...ow-plug-system
There is a video about halfway down the page.
Or here:
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Written instructions close to the top.
This is the easiest, simplest and cheapest fix. And it happens to be the most common. I wouldn't jump to any conclusions about HPOP, LPOP, IPR, etc until you test your GPR.
Or here:
Or here:
Or here:
I'm at a bit of a loss as it really does sound like a glow plug issue of some sort. Is it cranking strong or weak?
It might be worth checking the oil level in the HPOP reservoir. It should be about 3/4" from the top. For good measure you could check the tin nut on the back of the IPR just to make sure it's snug.
As I mentioned I know starters and alternators but honestly thought it was turning over a little slow, but not enough to cause the slow start.
