Push in door panel fasteners?
Anyone know where I can source about 20 push in style door panel fasteners?
My door panels for my '77 are plain ol' black molded plastic 'bout like what you see in all the usual catalogues. Difference I've noticed is my panels have 8 holes that correspond with the fastener holes in the inside metal door face.
I had to pull the panel to replace a broken outside door handle. Naturally, all but two of the fasteners heads snapped off making them useless. Didn't really bother me until I started looking for replacements. The body shop supplier I was sent to told me they don't make them any more. He had a handful in a box of obsolete stuff that he gouged me for. I even checked the automotive fasteners at Lowes and they didn't have any long enough to work for me. The ones I need have 1-1/4" barbed shafts with the big button head, and are black. They need to be that long to reach all the way to the metal on the lower half of the panel.
Makes me hesitant to remove the passenger side panel to replace the speaker!
Thanks for whatever info y'all can provide.
Thanks fmc400. I've done hit all the local parts houses around here. All of them had some, just none were long enough to reach the metal through the bottom part of the panel. Looks like I'll be ordering from LMC. Never would have thought cheap plastic fasteners would ever become obsolete!
Sounds like you found a source, but since you have the door panel off....now it a great time to put some reinforcement resin/2 part epoxy around the tabs on the back side.
Cause once you break that plastic up, it can be a bad deal to repair or get to work again properly.
And when you go to take the passenger side off, take a hack saw blade (tape the end you hold on to), and cut the old plastic press in stud/tabs. Carefully + I tape the top of my door, just in case.
That is how I take off door panels in the JY and not destroy them. Wish other folks knew that trick, like the guy that took these off.
And get the metal cups that you close the door with, instead of the plastic ones, a very good 13 dollar LMC investment.
Truck Parts and Truck Accessories
I get a lot of the specialty clip and hardware items from the local Ford store. The last door panel pins were bought about a year back. They fit and were the correct length.
A body shop supply store is another good choice.
I am always surprised at what the Ford dealer has in stock, and sometimes at what they don't, but that is another story.
Roger Carter
Roger Carter
I wish I had the type of panels that 77&79F250 has. I fear I have some antiquated, across the border type cheapos that aren't even available anymore (read "cheap").
I'm gonna attempt attaching a couple of photos; one of the panel with the holes visible (hopefully), the other of the long fasteners required to attach it to the door sheet metal.
Here goes! First shot at attempting to use the photobucket thing:
The top middle hole looks distorted on the panel because the head of the screw is showing. It's actually round like the rest.
Thanks folks! You have all given me plenty of options to check out.
460me: I'm hitting every body shop on the way home tomorrow to see what they may have on hand.
Roger: Two dealerships on my route home will get stopped at. One of 'em is a regional parts supplier for Metro Atlanta. Ain't gotta clue why I didn't even think of them to begin with. Duh, on my part.
GLR: WOW! Thanks for the link. If Auveco doesn't have them, nobody does. I'm saving that link in my favorites list. If I can't scrounge them up on the way home tomorrow, I'm definitely getting a pile of their item #15479.
