ford 5.4 zf6 swap
Its identical to 'Low' gear on the 6 speed that Ford labeled as a 5+Low anyways.
2nd gear and 1st gear is also just about the same between those transmissions. You just gain an extra gear for use in the middle. Which trust me would be great, but I've grown accustom to shifting less at this point, lol.
I've read that the 5.4l has a different bolt pattern than the diesel engines so you would need a gas ZF6 to bolt up to the 5.4l or an adapter plate. Another option would be to get a ZF6 and if it has the diesel bolt pattern just find the gas bell housing and it should bolt up I believe.
I believe the 6 speed for these trucks was the ZF6 regardless if it was gas or diesel, its just rare to fins one in a gas engine super duty.
Bell houseing and X/MIS all one piece.No seperating one from the other.
Thats because you dont have a 5 speed in reality, nor will you be obtaining a 6 speed, unless your towing all the time Id say. Unless im towing or creeping up a big hill (like my driveway!) I dont touch 1st.
I have no idea on how to post pictures here and my drive way is covered in snow and ice.Can't help you.
ZF6 Low is equal to ZF5 1st though, least on my 5.4 tranny.
Low in the ZF6 is 5.79:1.1st in theZF5 is 3.??:1 so not even close let alone identical.
hello all, I am planning on doing the swap as stated above for my 4r100. im a little stuck on something ive been reading up on however. so, everyone that seems to do this swap does them in 7.3 or 6.0. they all talk about how there is a spacer plate between the engine you need to change. however, when I look under my truck the engine is bolted directly to the transmission. is this supposed to be like this or do I need a spacer?
