'99 Explorer. I adjusted the hinge pins several times and have to really slam the tail gate several times before the gate closes and the interior light goes out. Does anyone have an idea to make it easier? Thanks.
It closes, but won't latch, right? Check that the tailgate handle is returning to the normal position, which is closer to the tailgate. When you squeeze the handle and then let go, the handle should return. If it doesn't, you may have to push it towards the tailgate. Then try to close it and see if it latches properly. I'm having this issue with mine at the moment but I haven't taken anything apart yet to figure it out. Could be a weak spring, sticky mechanism, etc. Too many other things to fix first.
If both sides close and lock the light goes out. I can feel one side not locking.
I worked on mine this weekend. One side (left) would not latch and the light would stay on. I lubed up the latch mechanisms on both sides. I also removed the interior panel and lubed up the lock/unlock mechanism driven by the handle. There was a pin with a washer that slid inside a slot and it was binding up so that the mechanism would not return to the normal position that the return spring was pulling it. The pin is located outboard (toward the door skin) of the lower rod that goes to the right hand side latch. I also lubed anything that rotated, but the pin/washer in the slot was the issue. You might have a similar issue with yours.
This would make more sense with a picture, but I can't figure out how to attach an image.
You can use the same user name and password for any number of websites if you want. If it's being used just put a 1 behind the name. Create an account with photobucket, upload your photo/s, copy the whole IMG address. In photobucket click on the photo and it'll bring up a larger picture. Click on the IMG box and it will copy automatically. In any website/forum type your stuff, skip a line and paste the IMG. Your picture/s will show when you post.
