adjust camber
Old 06-27-2003, 08:22 AM
Seifferlein's Avatar
Seifferlein
Seifferlein is offline
adjust camber
I have a 69 f100 and I can't figure out how to adjust camber. i have excess positive camber on the right side. Does anyone know?
thanks for the help
brad
Old 06-27-2003, 09:50 AM
BB's Avatar
BB
BB is offline
adjust camber
Like this:
Really! You need a good alignment shop that knows how to bend I-beams.
Barry
Old 06-27-2003, 11:42 AM
Seifferlein
adjust camber
thanks for the response. I had planned on letting an alignment shop do it, I was just wondering how it was possible - there aren't any nuts or bolts to loosen like newer cars. I didn't expect to have to have any parts bent. How much should I expect to pay to have this done?
thanks for the info
brad
Old 06-27-2003, 06:19 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
adjust camber
I don't know if you will find any one who bends them anymore. Ford now frowns on bending I-beams even though the picture is from a ford service manual. Usually it is just a ride height problem and most alignment shops will want to first restore the ride height. Most likely that will cure your problem anyway unless your kingpins are way gone. New springs are fairly inexpensive and are the best cure for the ride height problem.
Old 06-28-2003, 01:52 AM
baldavenger's Avatar
baldavenger
baldavenger is offline
adjust camber
i had a 68 f250 with excessive camber on the right side,come to find out the front axle pivit bushings were shot,i replaced them both along with the radius arm bushings and had the front alighned after that,and the problem was solved
Old 06-29-2003, 12:53 PM
baitmaster's Avatar
baitmaster
baitmaster is offline
adjust camber
the last time I had my '72 aligned, the technician told me he couldn't adjust camber. No adjustment to do, but he told me new springs would help, so I replaced them (easy job), and my 33's wear perfectly with the right air pressure.
Pescs334
1983 - 2012 Ranger & B-Series
08-15-2015 01:44 AM
SoCal949
2009 - 2014 F150
05-04-2014 08:24 PM
BlackBeest
6.7L Power Stroke Diesel
05-01-2014 01:55 PM
Native Gearhead
09-29-2003 06:34 PM
Quick Reply: adjust camber
