Please help.
Its not hard to replace a head, if you can handle basic hand tools and instructions you wouldn't have any trouble.
Easier than a motor swap yea however you should determine the condition of the remainder first.
How many miles on it?
How well did it run when it was last driven?
Maintenance records?
Miles it has about 80000 on it and when it last ran that's beyond me. Of course my brother in law said it ran good but started to act up had some people look at it and they where telling him to replace engine but I knew there had to be a cheaper route. And as far as maintenance no clue on that as well. Basically I'm starting from scratch so it's like a shot in the dark. I recently got my 1970 ford going and working well. So I figured I would tackle this truck to see if I could get it going and back In usable condition. Would local parts store have the valves( autozone or oriellys).
That way if the motor is viable it'll run if not won't have that much into it having to start over from scratch. Get a couple good heads they'd be salvageable in the end regardless, swap them onto a short block for example.
If all that looks good, you can also remove the valve cover, remove the coil to dist wire (so it doesn't start) and have an assistant crank the engine. If one of the valves isnt moving properly, it'll be pretty obvious.
If you do end up replacing the head, you'll need a gasket set, a torque wrench and perhaps new head bolts. a Chilton's would help you immensely for all the various torques and torquing order on the head.
nmto0777
13
03-04-2015 07:14 PM
bobs75f-250
04-07-2004 10:11 AM
