E serie seats compatibility
Hi there,
I am looking to change my front seats in my 88 e350, so i found 2 nice and comfortable captain chairs from a 92 palm spring e150 i guess, i would like know if they right bolt or if i will have somme mod to do?
Before i had a 83 f250 reg cab, i switch with a 93 f150 bench seat and it was right bolt.. i am wondering if it the same for the E serie.
Thanks
Thanks
Your '88 matches up to '91. '92 and later are different and the pattern on the floor and the floor itself are different. Not sure you can easily mod on to match the other. I sold the aftermarket seats and bases from my '85 and had a fellow with the later version come by and look at them. He looked at his set up and passed on my older stuff, saying it was going to be too much to change them over. I don't recall the details, but I think the older ones are too narrow for the new factory bolt holes.
Given the nature of the beast, I would look for seats that matched the original pattern and not modify anything. There are billions out there, so why end up with a compromise when you can get an exact fit.
Good luck with it.
Good luck with it.
Thanks, it's good to know, i thought that it will be easy to find my captain chairs but no way where i live. At 200 km (120 miles) around where i am, i find only the 92 palm spring captain chairs.
I am addict to modification, i also found for cheaper 2 captain chairs from a grand voyager, they are in tan leather, they will match perfect with my beige interior.
Also for the driver seat I am looking to adapt a mechanical suspension seat like the air ride seat in the semi. I found interesting idea with the mitsu montero frame seat. I plan to drive a lot with my cube van, so i need the best for my back.
Any advise about the driver bouncy seat?
The aftermarket lists them as:
'69-'74
'75-'91
'92-'95
'96+
Ford Van Seat Bases,driver,passenger seat bases
The seats may fit on the bases, but the bases won't fit on the floors as best I can tell.
Aftermarket seats seem to use a 8"x11" seat to base pattern. I have no idea what stockers are, or if they changed every model update the same as the base to floor.
'69-'74
'75-'91
'92-'95
'96+
I don't mean to highjack this thread but I was thinking of replacing my drivers seat with the seat immediately behind it (middle driver's side).
I plan on using the same driver's base but unbolting the actual seat bottom and swapping the two seats.
The reasoning is that my driver's seat is badly worn out and the middle row is almost new.
Does anyone know if it will work as easy as I think it will? (I never use the middle row seats)
Motroo
06-19-2014 05:49 PM
