Getting a siphon hose down that filler neck / inner hose may be a PITA. Esp. with the extra length/bends of a dually. You have to remove the neck/hose anyway, so you might want to remove it first, then you can shove the siphon down the outer hose. Might even want to pull that outer hose so you can put the siphon right into the tank.
