F-600 Questions
F-600 Questions
Hello All!
I'm currently looking at a 1993 F-600 4x4 that I might purchase, remove the flatbed that's currently on it and put on a dump bed. It has one of the Ford straight six diesels (there's a bunch of snow on the fiberglass hood and have been unable to roll it forward to identify the engine) and an Allison 4-speed automatic with a column shifter. What I'm wanting to know is if with this transmission, if the F-600 could haul a backhoe on a tandem axle, dual wheel trailer?
If more info is needed, I can certainly do some more digging, or in this case, snow removal.
THANKS!
THANKS!
If your use to the pickup Allison, these are a lot different.
nevrenufhp, I finally got my 8.3 running good. Boost hose was worn through and the racor fuel filter was letting air in around the pump. Then I took the top off the p7100, its good now.
SO! The snow has melted enough out west here and so I rolled back the hood on the truck and to my surprise (and ultimately, my dismay) it has the 160HP 359 CI Cummins (the 5.9L).
This now spurs another question... would it be worth the time and ultimately the money to dump in a 270HP Ford 474 CI Diesel (the 7.8L)?
Your thoughts much appreciated!!
by-the-way, the VIN is 1FDWK64C9RVA24045
thanks again
thanks again
I realized after I posted my last comment that I wasn't thinking at all. First, the 474 and its little brother are good engines but very hard to find parts for it. When it comes to modifying & tweeking the engine's performance the Fords are a bit of a lemon. Where as the 359 Cummins has all sorts of performance parts available and it's still being produced.
Sorry! I didn't know what I was saying. I would keep the Cummins and build it up.
Thanks for the help.
1993 F-600 4X4 / VIN: 1FDWK64C9RVA24045
1FD = FoMoCo USA - Ford Truck (Incomplete Vehicle).
W = GVWR Class 6: 19,501-26,000 lbs.
K64 = F600 Diesel.
C (1993/99) = 5.9L (359 cid) Cummins model FD-1060 I-6 diesel.
9 = Check digit, FoMoCo use only.
R = 1994.
V = Kentucky Truck Assembly Plant.
A24045 = 1994 Numerical Sequence of Assembly.
