shift indicator cable 1991 ford truck
Received 3,110 Likes
on
Shift Indicator
I had to buy mine at the Ford Dealer.
You have to remove the trim surrounding the Cluster and, if I remember correctly, pull the speedometer.
As I recall you do not have to remove the Instrument Cluster just the clear cover. Also, you have to remove the steering column cover, put the shift lever in low to do this.
On a good note: you can adjust the cable so it is "dead on" the gears and no more half in, half out.
Take care.
Boon
P.S. Once you get started you will see that it is not that hard. On my 87 I just needed a phillips screwdriver and a torx #12.
mixgashaulass
03-26-2013 09:27 AM
johare
1983 - 2012 Ranger & B-Series
06-07-2005 01:32 PM
