Turn signal headache!
Hi all, recently i thought i had a bad flasher so i stopped and picked on up. When i put it in, i now have no turn signals at all! Before i installed the new flasher, i could manually use the turn signals by had and now i have none at all with no signal lights on the dash. The hazards lights work and i checked the 15 amp fuse and it's fine. I'm lost and could really use some expertise from you all! FYI i also put the old flasher back in and still nothing. Thanks...
recently lost turn signals on my 97 the other night. checked fuses and all were good, turn signals were all i lost. had markers headlights, tails, and brakes and also hazards.
so talked with my uncle, the tick sound you normally hear with every flash of the turn signal is the round silver thing in the fuse panel under the dash, and there is one on the front side for the turn signals, and one directly behind that on the back side for the hazards
check to see if you have hazards and if you do, pull the silver circle one out on the back side and put it in the front side and see if you have turn signals, both outside and on the dash. that fixed my problem and i just replaced the bad silver circle one with a good one out of my parts truck and have turn signals and flashers.
cigarxtc
32
04-07-2018 12:00 AM
f350hammer
02-09-2014 08:08 AM
Agemenon
12-18-2007 09:58 AM
