Carb Linkage
Carb Linkage
Hello to all.
I have a 215 c.i.d. OHV. There is a small link that goes to the carb from the pedal linage ( right behind the carbureted). One end is round and slips over the ball end of the linkage directly to the carburator. There is a clip and spring in the shaft of this link. Every now and then it slips off and the engine goes full throttle. Anyone know how to get it to stay on, or where I can purchase a new one!
Also, my starter cranks and then winds or spins. I'm assuming it's the starter. Is there a particular part of the starter to replace or am I looking at replacing the starter?
Thanks in advance for your help.
I have a 215 c.i.d. OHV. There is a small link that goes to the carb from the pedal linkage (right behind the carburetor). One end is round and slips over the ball end of the linkage directly to the carburator. There is a clip and spring in the shaft of this link.
Every now and then it slips off and the engine goes full throttle. Anyone know how to get it to stay on, or where I can purchase a new one.
Complete part number TRAA-9772-A .. Rod Assy-Bellcrank to Carburetor / Obsolete
1952 F1/F5 215 I-6 / 1953 F100/600 215 I-6 / 1954/56 F100/600 223 I-6 S/T & O/D.
NOS PARTS LTD in Waxahachie TX has ONE = 972-937-2201.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
Lower pic:
Couple of quick notes:
If the engine goes into full throttle, MAKE SURE YOU HAVE A GOOD RETURN SPRING! I totaled one of my 54's when it stuck full throttle due to a mechanical failure. Autozone, etc. sells a universal return spring if that is an issue.
As for the starter. They use a bendix that can and does get weak and fail. I actually found that the ones on 6 cylinder Ford tractors of the same era use the same bendix drive and often available at local tractor stores for less money.
There is an "improved" design Bendix out there, no personal experience, other than the old one is a PITA. Shop around, this is the first place I found with it: BENDIX DRIVE, STARTER - Starters - Flathead Ford Performance - Hot Rod Parts
The 215 starter bending is slightly different. I'll EDIT this post with a picture later today.
EDIT: Here's the starter Bendix for a 215/223.
