Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-26-2003, 06:29 AM
Trackhead Trackhead is offline
Garage is empty, add now
Trackhead is starting off with a positive reputation.
1600cc rough idle when warmed up
Not sure where to post this...Anyway, my snowcat has an old 1972 Ford 98 CID/1.6Liter/four cylinder industrial engine (Pinto basically). Starts great, runs great until warm. Then has a very rough idle to the point of near stalling. Once the RPM's are a bit higher it runs fine with good power, etc. Vacuum leak? Any tips? Thanks in advance.
Click the image to open in full size.
  #2 (permalink)
Old 06-27-2003, 08:00 PM
canzus canzus is offline
canzus is starting off with a positive reputation.
It's not a Pinto, it's a Kent, and it may have
carb troubles, idle circuit may be kinda lean too
little fuel, check the idle mixture screw is about
2 or so turns out from gently all the way in when
hot.
__________________
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'74 Capri 2L
  #3 (permalink)
Old 07-06-2003, 05:10 AM
shotgun shotgun is offline
shotgun is starting off with a positive reputation.
Probable a gummed up idle circuit.
__________________
Chris
1996 F150 classic:
Last year for:Twin-I-beam front axle, Body style, 300 straight six, Wing windows
F150 4.9L, 4x4 XLT, EXT CAB, Warn manual locking hubs
ZF5-SPD, 3.55 Factory trac-loc in both axles
BFG All-terrain KO 32s"
Tags
1600cc, 1973, 4cyl, 98cid, carberator, engine, ford, idle, idles, industrial, kent, motor, pinto, rough, truck, vacuum, warmed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
