Fuel Filler hose
Fuel Filler hose
Anyone tried this method in replacing the fuel filler hose?
https://www.ford-trucks.com/forums/3...ml#post3595850
I grabbed the picture before the link went bad, Ill post it asap.
Also just to clarify, which tank is the AUX tank and which tank is the MAIN. I have 2 tanks, one is directly behind the cab, not in cab, the other tank is above the spare wheel behind rear axle.
Thanks for the info & clarification fellas.
I went ahead and ordered the rubber from Dennis Carpenter.
Fuel Tank Filler Hose | Dennis Carpenter Ford Restoration Parts
Anyone know if I need to drop the tank to replace these hoses properly?
Tips on how to do this the best way?
Not sure on the length, but you could probably call a supplier(Dennis Carpenter)DC or whomever) and see if they can give you a length. Or I could go out tomorrow and give you a rough guesstimate.
Since the gap between the bed and the frame is small, you will need to unbolt the tank(after undoing the hose clamps at the tank) and let it drop a few inches so you can get the new hose around the neck of the tank. That's the hardest part. After that, the rest is easy. I bought mine thru my dealership, they stock DC filler hoses. it was a pretty good length with one end angled. I used the angled end at the gas tank neck.
Hopefully this project will happen in the next couple of weeks, if you get to yours first let us know how it goes.
KiwiFord
18
01-24-2011 03:20 AM
mighty ford
08-11-2007 03:45 AM
thegreytruck
04-30-2007 12:06 PM
