Disc Brake Install on scale 1-10
Old 12-31-2013, 07:08 PM
baumst's Avatar
baumst
baumst is offline
I can build Ikea furniture and barbecues and I was most excellent with my son's Legos...
Converting the drum brakes to discs on my 1960 F100. Skill level needed?
Now I have done a few things myself on the truck, mostly in the electrical or coolant system. I tend to stay away from stuff underneath but suspension stuff.
I want to buy a kit and make my truck stop (safer).
Bonus:
223 I6 with 3 on tree. Original clutch, brake masters... Original Air Cleaner. Which power booster should I buy, that fits without any mods?
Old 12-31-2013, 07:24 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
I've used CPP kits without issue. Clear instructions and good quality but not cheap. Others with chime in soon I'm sure.
Classic Car and Truck Brake, Steering and Suspension Parts
Old 12-31-2013, 07:45 PM
Choptopjimmy's Avatar
Choptopjimmy
Choptopjimmy is offline
Speedway sells a reasonably priced kit. Seen some kits on eBay also. You will need to feel comfortable installing the front wheel bearing and bending new brake lines to install one of these kits. You should install a dual reservoir brake cylinder when you do the upgrade also. Good Luck. Jim
Old 01-01-2014, 09:05 AM
Walston's Avatar
Walston
Walston is offline
For someone with reasonable mechanical skills it is about a 4 on the scale you mention. No welding, but you need to be able to bleed the brakes when finished. There are other things you should consider at the same time.
I would check out the steering condition. Tie rod ends, drag link and the king pins when you do the work, no better time to change them and they go a long way to improve steering and safety.
King pins are likely the hardest, but doing it now only makes sense if they are bad, you are removing everything except the spindle to install the discs. We can help on how to do it. May need a torch to get the old one's out.
It find out if they are bad, raise the truck and grab the top and bottom of the tire and wiggle. If the king pins are bad, there will be movement (play) when you try to move it back and forth. If no movement, they are fine.
Old 01-01-2014, 01:31 PM
baumst's Avatar
baumst
baumst is offline
That's exactly why I wrote this Walston.
It's funny, I had the local mechanic put a new clutch in my truck instead of me in my driveway. We changed a few other things like the rear end pinion seal and the driveshaft u-joint but I had him do it all so I wasn't sitting there in my driveway with a mess. The three-four hours labor he charged was worth it.
I believe I can do the brakes and if I got stuck anywhere it would probably be brake lines and bleeding them out for optimum performance.
You mentioned king pins and a "wobbly" wheel. While I was planning my brakes, I was also gonna go in and change all the spring pins (they are worn!) and such but never thought to change the king pins. And I hear torch to remove and that's the other dilemma. If it costs me a $100-$200 in tools or three hours labor to do it right with someone that has the tools, I am gonna pay the right person with the tools. My mechanic said I needed new wheel bearings and I figured I would do that with the brakes but I questioned him because we did that a year ago! Now I definitely thing I need king pins.
My drums work fine. I just want to stop for the deers! I believe they have been done in the last 5 years because of all the "nuts and bolts" under the truck, the brake lines are the shiniest. When I step on the pedal it stops so... I have had the truck three years and the previous owner was in restoration mode (new interior, paint, wheels, etc.) but he had not made it to the suspension, drivetrain or much else as I later found out (blew radiator first hot day, no thermostat...). He did upgrade the distributor, added the alternator and installed a brand new heating system. I am just doing the nice, daily driver 3rd car thing...
I have a $1000 to spend and I think this time around I am going to wait on the brakes for 6 months and maybe get under and replace all the nuts, bushings and what not in the steering. I'll dedicate the big spend to new leaves.
I
Old 01-02-2014, 07:01 AM
Walston's Avatar
Walston
Walston is offline
Here is something to think about. If you are gonna remove the springs and the brakes, if you disconnect the shocks and the drag link from the steering box, you can remove the entire front axle / spring assemble and refresh everything on the work bench.
This first picture was a joke at the time, but you can see the assembly. Bolt on the spring and it it ready to reinstall.
Old 01-02-2014, 12:23 PM
baumst's Avatar
baumst
baumst is offline
Yeah... this whole thing turned into "replacing all steering components" for a safer drive. Thanks!
MrJNice
02-13-2015 02:31 AM
baumst
03-15-2014 07:03 AM
63' f100
06-29-2009 12:22 AM
6T6Shorty
04-14-2006 06:16 AM
Jason62
05-15-2002 08:15 PM
Quick Reply: Disc Brake Install on scale 1-10
