302 ignition problems
My 302 has no fire. I have redon the whole ignition all the way down to the switch. A freind told me to replaced the magnetic pickup again. I did and it ran for a few minutes, cutting off every few seconds. It was backfiring a lot in the process. It backfired one time and the motor started turning in the opposite direction. Does anybody have any Ideas of what could be wrong?
Plug wires on wrong. Check your firing order. There are two available.
Later 302s use the same order as the 351W.
58912497.gif Photo by Marios_03wrx | Photobucket
And do you have the distributor in correctly and lined up with TDC etc?
Amenjephra
17
11-14-2002 11:47 PM
