Might change to AC code injectors - flash ECM?
Yes you can have your PCM flashed so that it will run with the SS injectors properly. I have singles in mine and even though I am running a DP Tuner my PCM is flashed so that in case the tuner gives up the ghost my truck will still run via the PCM.
Your truck will run with the SS in them just not as good as it should and not as efficient also.
I posted this in the 7.3 forum, and am getting answers there, so here's that thread:
https://www.ford-trucks.com/forums/1...o-ac-type.html
Thanks megawatt00
Thanks megawatt00
Pikachu
12-27-2013 09:04 AM
