Modular V10 (6.8l)
2000 V10 cranks, but no start
Old 12-27-2013, 04:30 PM
SZAlbNM's Avatar
SZAlbNM
SZAlbNM is offline
It has been running very well. I parked it in the driveway overnight like normal and tried to start it for work in the morning. It cranks, but does not start. Doesn't sound like the plugs are firing. The electrical accessories work, the gauges act normally, but no tachometer movement while cranking. Pressed on the gas pedal while cranking, no start. I tried both keys and both will crank, but no start. Disconnected battery for 1 hour to reset anti-theft, still no start. Fuel in the rail and fuel pump seems to be running, compression tested 1 and 6, both 130 PSI. I tried to get spark (spark plug in COP, grounded to valve cover bolt) and there does not appear to be a spark. The PCM has no codes stored. This is my primary vehicle. What should I try next?
Old 12-27-2013, 06:19 PM
jayjjcc's Avatar
jayjjcc
jayjjcc is offline
Do you hear the pump charge when you turn the key to on? I wouldn't give it gas while cranking... wouldn't want to flood it...
Old 12-27-2013, 10:15 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Moved to the 6.8L V10 forum.
Stewart
Old 12-28-2013, 07:25 AM
Shepherd2's Avatar
Shepherd2
Shepherd2 is offline
Never mind.
Old 12-28-2013, 01:42 PM
Areford's Avatar
Areford
Areford is offline
Did you check the IAC valve? Could be stuck as I had a similar issue.
shades556
10-19-2015 05:31 PM
Spamy
Modular V10 (6.8l)
12-05-2010 04:02 AM
lp3509
1999 to 2016 Super Duty
01-19-2010 04:59 AM
Quick Reply: 2000 V10 cranks, but no start
