torque value help
Copy and past after a quick FTE search.
"75 shop manual says 50-75 ft-lbs and then advance castle nut if needed to get cotter pin installed" for the tie rod.
Drag link....
http://www.google.ru/url?sa=t&rct=j&...58187178,d.bGE
Drag link....
Of all the front end work I've done, I've never torqued any linkage nuts/bolts. If I'm using hand tools, I just get it two hand tight and then tighten until the castle nut lines up. Most of the time, though, I use an impact wrench and just snug up the nut and then turn until the nut lines up for the pin.
Of all the front end work I've done, I've never torqued any linkage bolts. If I'm using hand tools, I just get it two hand tight and then tighten until the castle nut lines up. Most of the time, though, I use an impact wrench and just snug up the nut and then turn until the nut lines up for the pin.
Kozo
04-05-2013 06:41 PM
GeneStoner
02-03-2005 10:37 PM
