Leaking bleeder screw?
Ok, so I feel dumb I can't figure this out but I have no idea why this is happening.
Installed new caliper, pads, master cylinder, bled the brakes and was about to take it out for a road test and I noticed the bleeder screw on the new caliper is leaking. At first I thought it was leaking from the threads but I had my wife apply the brakes and it is leaking out of the "bleeder orifice" regardless of the position of the bleeder screw....no matter how tight or loose I have it.
Would like to get this done so I can bleed the rears and start using this thing!
Thank you for any help!
I understand it's a new a caliper, but it's possible something is stuck inside the bore and preventing the screw from seating completely. I'd start by simply removing the screw completely and checking for obstructions in the bore and on the screw. Make sure to use a flashlight and look directly into the bore- it could be something easily missed otherwise.
If there's no obstruction, it could just be a faulty bleeder screw and you need to replace it.
So it was something wrong with the reman calipers? They are cheap but, I just got the tires back on and off the jack stands!! What a pain in the butt! Can't they sell us quality products??
I THOUGHT I had fixed it. I removed the bleeder screw, set it aside, didn't see any obstructions in the way. backed out the bolt holding the brake line in, reinstalled bleeder screw and then tightened the brake line bolt. It definitely slowed it down BUT....it still comes out in spurts, inconsistently....not sure about that. Anyways....
I am VERY close to just saying forget it and returning this. It is very aggravating to know that there is such a high failure rate with out-of-the-box products...especially ones that could kill you if you are driving with any speed....
Over the past 35+ years I've replace countless calipers/wheel cylinders, no way to even hazard a guess as to how many exactly, and from who could say for sure how many different suppliers/re-builders and I've never had a bleeder leak on one yet.
If I did first thing I'd do is yea inspect the bleeders seat, doubt be any problem in it but I'd look make sure its clear of crap and formed right yet (Make sure some bonehead didn't bury a drill bit down the hole trying to remove a snapped off bleeder the re-builder might have missed). Satisfied that's good I'd run down get another bleeder a minute try it. If it's seat is good the bleeder must be deformed allowing fluid to pass. Bleeder for example might simply be wrong angle or reach or both for the seat or fit to loosely of thread to snug up like it should.
Ok, so I might have done something wrong....I may be a washer shy on the brake line.
So, the "block" on the brake line that the bolt goes through....the old caliper had a washer between it and the caliper surface and another between it and the bolt head.
The new caliper came with one washer so I stuck it under the bolt head, the traditional location....should I have another washer between that block and the caliper surface?
I am thinking that this bolt is in too far and is interfering with the bleeder screw? Does that make sense?
Sorry I haven't messed with calipers all that much other than R&R's on different vehicles over the years Ive never gotten into depth on them so THANK YOU!
