95 5.8l will not restart
Took the truck out today in a freezing drizzle to pick up salt for the drive. I let it warm up a good 10 minutes and got in and drove about two miles before I noticed sputttering. I hit the throttle a bit and it shuddered and shut off. Ok, restarted and took off again only to notice more sputtering and finally died on the side of the road. I tried to restart it and drained the battery in the process. I finally had a good soul stop and give me a jump after about 1.5 hours and thought that I was almost out of gas as the gauge on both tanks don't work. I made it to the gas station, left it running, and pumped only 4.5 gallons in the rear till it was full. I put 1.5 in the leaking front (leaks only when more than half full). I revved the motor at the gas station and it sounded good.
I drove straight home and left it running in the drive for another 10 minutes. It ran pretty well. I parked it, shut it off and restarted it and everything was fine. I decided to try and start an hour later and it would crank and crank and almost catch, but no start. I kept trying till the battery started to die and now I am in a quandary.
I checked some forums and didn't see anything that jumped out at me. I don't have a code reader and i don't have the funds to start swapping parts out. I need some help as to what the problem could be or where I should start. I poured some Stabil in the full rear tank, hoping I have water, but it did not magically work.
Any help would be much appreciated as we are going to be hit with a big storm and this is my plow truck.
update
Truck started fine and i was able to plow my drive for 20 mins or so before I noticed sputtering. After I had made a couple of long passes, I started to work the truck hard and revved her up. No problems, maybe a slight miss, but plenty of power. Snow was about 10" deep, but not too heavy. Ran it a bit more and almost died when i quickly gave it more than half throttle to test how bad the sputtering was. I let the truck sit a couple of hours and started it back up and plowed another 15 minutes before it just started to sputter.
I have not done done any diagnostics, as i need to find the link to testing for codes with the wire. I do not have a CEL. Distributor cap and wires "look" old. I am leaning towards changing the distributor cap and rotor, wires and maybe ignition module as the plugs were changed out 3 years ago when i replaced manifolds. I figure I'll take a look at it once the weather get a touch warmer.
Thanks for the input and if anything i babbled about makes sense, let me know.
4.9inline6
09-30-2011 11:26 AM
rockinout5432
17
12-30-2006 08:52 PM
