1951 F3 Project
#32
Ordered the clutch kit from Rockauto. AMS AUTOMOTIVE Part # 07518 under 1951 FORD F3 3.7L 226cid on their site. Also ordered new pressure plate bolts ARP 150-2201. Finally had some time Saturday evening to get it installed.
Fly wheel installed
Clutch and Pressure plate installed
Bell housing installed
Fly wheel installed
#33
#34
Putting the m/c on the firewall means converting to hanging pedals. Or at least, the brake pedal. It might be awkward having a hanging brake and through the floor clutch. That's your call. For a replacement dual-circuit m/c, I'd choose one from a circa~1969 F-100 with manual drum brakes. It should be sized pretty close to work with the stock brakes.
#36
#38
#40
#42
Those aftermarket booster/MC combos will work but they are NOT a direct install into our F2/F3 trucks. I had to modify the mounting flange quite a bit, the bolt pattern for a F1 is different. At least it was on my Long Beach plant built truck. at least one other member with an F3 has said the same thing and had to modify to fit. also keep in mind that the inspection hole in the cab floor will no longer be of use since the MC is now further away. With the cab off the truck you can fill the reservoir, or you have to cut a different hole in the floor and it may interfere with your seat track.
Tom
Tom
#43
#44
Well i didn't get the motor running but i did get a couple things done. I got the radiator cleaned and mounted. Made gaskets for the water pump and thermostat housing and installed those with a new thermostat. Pulled the front drum brakes off they are pretty scared up not sure they are going to be able to turn them....but i tapped the wheel studs out any ways.
I also order a new master cylinder from rock auto and wheel studs. Picked up a 12v coil on Saturday. Debating on which wiring kit to order. any recommendations. There are really no wires that are useable so a kit should make it clean and easy to pull since the cab is the only body part on the frame.
#45
