2001 F250 7.3 4x4 Brake Problem
Posting for a friend but please point me in the right direction.
A few years ago I (for him) replaced all 4 calipers, rotors, pads, etc....things were good.
Just recently he replaced his Brake Booster and Master Cylinder (not sure what led to this), but long story short everything is back together and he doesn't have brakes.
My GUESS is that the system needs a good flush, new fluid, etc....
My problem is I'm unsure how to bleed the ABS system. A few google searched indicate I need a scan tool, but is there another way? Can I jump something.
So my question, how do I completely bleed the brake system on this truck?
Thanks in advance for your replies!!
-JOE
-JOE
Legitimate question!!! Pedal goes to the floor so I'm certain there is air in the system. I'm ok with bleeding system, just concerned about the ABS part of it.
Received 3,108 Likes
on
The brake pedal does return to the normal position when you Leticoe however it goes to the floor with little to no pressure. I remember when I replaced as calipers last year that we had to pump the brakes for probably five minutes before I was able to build any pressure on them and actually flush the lines appropriately
I apologize for any miss types I'm currently talking into the iPhone and letting Siri figure it out.
Purchase yourself the pump style brake bleeder that attaches to the master and bleed. If you have deep pockets get a power bleeder cats meow. Start from the furthest bleeder (passenger rear) working your way to the closest(drivers front). The antilock portion was likely not disturbed. If it was Im not sure how to go about forcing a bleed on this circuit. Refer to the Ford service manual or Google.
Yes bench bleeding is basically getting all the air out of the front & rear cylinder circuits and is a must do upon master cylinder R&R.
Tbark94
11-17-2018 01:03 PM
wolfgang031691
1997 - 2003 F150
11-18-2009 09:13 AM
