radiator question
That's a 48-51 flathead 6 cyl because of the angle the top tube is positioned. For 52 6 cyl motors, the upper tube came out at 90* and not 45* like the 48-51 flathead 6. The 45* angle will not allow for a proper installation of the upper radiator hose unless the upper inlet is changed to 90*. Otherwise, the radiator is the same.
I may have the correct 52 OHV 6 radiator. I'll need to check.
Couple of reference pictures for you.
drptop70ss
07-27-2015 03:00 PM
rcav8or
15
10-15-2007 10:01 PM
tomrooster-1
1947 and Older Ford Trucks
09-26-2006 07:51 PM
