Question on 5.4L in 2000 Expy Eddie Bauer
Hey y'all,
Just a quick general question about oil viscosity/type in my 2000 Expy E.B. 5.4.
This is not an "oil thread", but a thread with a request for clarification.
I know in the past LX1Man has posted extensively about the piston slap/knock the 5.4 is famous for and the reasons for that.
Per the dipstick for my 5.4 it calls for 5-30W oil which is what I put in it this past June when I serviced the truck (it only gets an annual service due to very limited miles, it's a spare).
I used the 5-30W because I tow a 5K lb travel trailer with it and figured when it gets hot, an engine of this age (has about 108K on it) would benifit from the thicker oil.
If I remeber correctly LX1Man has stated in the past the 5.4 was designed to be a 300K mile motor by Ford and my 5.4 does seem to be pretty stout yet for 14 yrs old and over 100k.
My issue is that I notice some piston slap/knock when it's cold using the 5-30W. If I also remeber correctly LX1Man advised it's OK to use 5-20W in my vintage 5.4 and that helps with piston slap/knock. I have run 5-20 in the past and the slap is not as bad with the thinner oil.
It's not horrible with the 5-30W, but is more noticeable. So to make a long story short, should I stick with the 5-30W because I'm working it hard to tow the travel trailer, or do you all think 5-20W is OK even working it that hard in the summer months.
Remeber, I only run about 2500 miles per year with it so I only change the oil once per year, right before annual inspection.
Thanks for any thoughts or suggestions.
Sincerely,
Greg
Sincerely,
Greg
5w30 is ok to run. Around 2001 they switched to 5w20. This is a bit thinner and will reach the heads faster on a cold start-up. It also puts a little less drag on the oil pum so it may free up a hp or two. The main reason that they switched to 5w20 is to try to get every possible mpg improvement possible.
That being said, it is really up to you. The 01 that I had always ran 5w20 and I have towed 7500lbs+ in 98 degree weather and the a/c on with no oil issues at all. I always used Motorcraft semi-synthetic 5w20 and a Motorcraft filter.
Thanks again,
Greg
