6.4 exhaust smell in cab/Turbo mising two bolts
lately ive been noticing an exhaust smell inside the cab, possibly through the air vents. through some thorough investigation, I found that there are two holes on the side of the turbo under the heat shield, that are empty (it lools like they might connect the two turbos). it seems there should be two fasteners in these holes. I was wondering if I could get others input on this issue, as im not 100% sure anything goes in these holes. *Note: still trying to figure out how to insert a picture. will post when I figure it out.
I didn't notice any soot on the heat shield, so I think I can rule the turbo out. I did however find some build up on the ends of the pipes go to the inter cooler, as if the hose clamps aren't tight enough. I tightened them up and the smell isn't as prevalent, but still existent. I will poke around under the hood this week for some further investigation of the down pipe. Thanks for the input.
ghunt
02-04-2008 08:41 PM
