Block heater
Block heater
Just found out that my 2012 f250 block heater isn't working. Would not start with remote but thankfully she fired up using the key(barely it wouldn't even idle). It was -43c with wind chill last night. I tried 2 cords and 2 separate plugs and can't hear it kick in(telltale sizzle). My lovely wife is going to take it to the dealer this week but I just asking if I am possibly overlooking something simple here. I don't believe they are on a relay or anything so I'm thinking bad cord or heater itself. Truck started though so that's a good truck I my opinion.
I believe we were somewhere around -36 without the wind. I don't drive the truck everyday so I plugged it in for 2hrs before trying but I thought something was up when I couldn't hear the telltale sizzle start after a couple minutes. Someone asked about the block heater in general and yes they come std on vehicles in our climate here. The cord end is just clipped up inside the front bumper which sure beats having to dangle it out of the hood like the old days.
My previous 2 diesels had engine block heaters and I could not hear them at all and really couldn't tell they were working but when I start in the cold you knew right away if it was working.
I did do an amp draw on mine to test. They only pull about 4 to 6 amps on the diesels so it would take a long time to heat things up. I have not checked mine on the 6.2l yet.
I just googled how to test the block heater with I multi meter and its really easy so I will check it before sending it down to the dealer. We don't need them everyday just during extreme cold snaps. It would prob start anyways but it sure is easier on them when they're plugged in. Until your wife drives off with the cord lol. I have a cord with a really loose end that I use on her car, it is perfect, her block heater works and when she forgets and backs up it just falls out yet stays plugged in to the house.
That is odd that you have issues using the remote start when it gets cold. It has been down in the -30's (-40's with the wind chill but that is of no consequence for an inanimate object like a truck) I have not had any issues with mine and my battery is half shot 450cca vs the rated 650 or so it is supposed to have. I haven't even plugged it in yet this winter.
Had the same problem with mine yesterday and this morning at -40 and -35 with windchill. I know mine works because I see sparks when I unplug it.
Remote start without plugged in works fine in -20 but it seems that -30 and worse will require the block heater and to get out start start with the key.
