Trailer Wiring electrical gremlins
Good graphic!
And you have power to multiple pins in the plug at the right and it corresponds to you turn signals and brake operation?
It looks to me like that is the main harness to the rear. Did you check the leads ahead of the juncture on the left, that is, do you have power on the leads immediately after the plug as in "to the plug and through the plug" in the right in your graphic?
Steve
Steve
I wish they would stop noting it on the Internet examples and simply note the relationship between pins and functions. I think it would stop screwing up a lot of folks who think colors are universally designated when it actuality they may mean nothing at all.
Steve
You are right, it is better, but I wish they would leave out the colors completely. It is fine if you are used to wiring, but a lot of folks aren't and that is always my concern.
Some of the dump trailers I have wired are crazy. They actually spliced leads and changed colors for the same function three times on a single lead. The color you started out with had nothing to do with the color you ended with or the color you traced mid-way in the circuit.
That's the craziness. Once you understand this stuff you quickly realize you can wire it anyway you want as long was you understand what you are doing and match your trailer to your truck. Of course the next owner is screwed, but a lot of folks don't consider that!
Good graphic!
Steve
Steve
I need to figure out for sure which pins on that connector I don't have power too once the battery is charged back up. I know I had two that had power and I think they are black and orange, but I have to check it again.
I don't think this is a wiring issue. I think it is a power supply issue, which is what it sounds like you are gravitating towards also.
I don't know your specific truck, but I did a 99 250 not long ago and it had the box under the hood. I am guessing you checked that and you used your test light on both fuse legs so you know there is power to and through the fuses there.
Steve
Steve
Had to resort to a temporary fix as this truck must have trailer lights in the morning. I spliced the yellow/green to the green/orange on the truck to get power to the trailer turn lamps, everything now works. Still not sure why the trailer half of the wires are dead at the frame rail connector - this is tested at the incoming side of that connector so I'm certain it is a power issue not a wiring issue, at least not a wiring issue that's past that connector.
Orange - has power (Auxiliary)
Brown - has power (Running lamps)
Green - no power (right turn)
Yellow - no power (left turn)
Blue - no power (brake controller)
Black - no power (12 volt)
Tested every fuse both sides and everything else I can think of and I can't find the problem. Hopefully I can find the source of the problem and fix it correctly at some point. By the way the other half of the wires in that connector that power the rear lights/turn on the truck all have power and work as they should.
#28
#29
