another spacer or lift springs
I'm starting to look at lifting my truck 2 more inches. Right now I have a 2" under spring perch spacers in the front and a solid 5.5" rear block. I can get another rear block at 7.5", but my question is the front. I do plow with the truck so front end stability and safety is an issue for me.
I really like my stock front snow plow springs and with a v8 keep me about an inch higher then stock unloaded. I had a few thoughts that I want help with
-get a bigger (4") below spring spacer
-add a 2" above spring spacer to go with my 2" existing spacer
-get an aftermarket lift spring but those seem pretty soft to me
-any other options anyone can recommend
I do know I will need radius arm drop brackets and a drop pitman arm, etc, etc ,etc. I'm thinking about buying a Rough Country 4.5" lift for all extras and using my own blocks that I will get from Newton Lifts.
I was looking at these springs for their added capacity and height but I'm worried they may be to stiff unloaded
http://www.generalspringkc.com/product_p/ttc-2813.htm
Received 3,108 Likes
on
