Thermastat stuck shut?
Three questions:
My factory temp needle used to get close to the R in NORMAL but for awhile now it rarely hits the O, and never gets past the N with no trailer hooked up.
So could it be stuck shut?
Where is your guys needle pointing at?
Also what was is the stock temp on the '95?
on
1 Post
Running a t-stat that is stuck open is not good. The coolant is not regulated and free flows through the engine and does not have time to absorb the heat from the block and carry it to the radiator. The gauge will read cool because the coolant is not absorbing the heat, and the engine is actually running hot.
It was also in the low 30's that day, and at highway speeds, that queen sized rad. Will keep the coolant nice and chilly
143 is low.
Had a guy tell me he installed an international pump and his truck was now running 173 the other day as well with a 196 t-stat. *facepalm*
The t-stats for our trucks tend to fail if you pick them up at the parts store. Mine doesn't operate properly itself.
Worked great for about 3 months.
